[WTR] 7/23-7/24 - 12" Powered Speaker and 15" or 18" sub with tech needed in Houston
304
San Francisco, CA
I need to reserve some equipment and a tech in the Houston area for a noise transmission test. The equipment will be needed at the following locations:
2549 Kirby Drive, Houston - July 23rd, 2:30 PM
Woodway Collection (1407 S Voss Rd), Houston - July 23rd or 24th.
The dates/times are not 100% solid but the locations are. The tech needs to deliver and set up the equipment, assist an acoustical engineer with operating the system while she conducts sound level measurements inside the space and in adjacent spaces, and then strike the equipment. Repeat at the second location.
Please contact me directly at daniel dot postilnik at soul-cycle.com if you are available and I can give you more details.
Thank you!
Re: 7/23-7/24 - 12" Powered Speaker and 15" or 18" sub with tech needed in Houston
BUMP!
Date: 8/10
The equipment is needed at the Woodway collection location from 8am-10am, then moved and re-deployed at the Kirby Drive location from 12pm-2pm.
