Re: Most prevalent Ethernet based DMX protocol? Artnet?
Streaming ACN (Standard)
ETCnet (ETC proprietery)
Strand ShowNet (Strand proprietery)
MA Net (MA Lighting proprietery)
ArtNet (Artistic License proprietery, freely available)
KiNET (Color Kinetics proprietery)
The great thing about standards is that there are so many to choose from.
sACN and ArtNet are the 2 protocols you will see on the widest variety of hardware. The manufacturer proprietary stuff is generally limited to that manufacturer.
ArtNet was around first, and is quite common on freeware and shareware software. sACN is a lightweight version of ACN, which is an official standard. sACN is available for free as well, and is growing in popularity. The two protocols are fairly similar, however, they way they work on a network is different. ArtNet uses broadcast protocol whereas sACN uses Multicast. The broadcast protocol is super easy to set up, as your devices simply need to be on the same subnet to work, but there are issues with saturating a network with broadcast packets.
The next step beyond is RDM, which is a 2 way communication protocol. DMX is only one way, so your console doesn't get any feedback from devices to know what they are or if they are even there. Having the ability for the lights to talk back to the console opens a whole different set of exciting new options. e.g., if a fixture is having problems, it could tell you, instead of just sit there and act dumb.
This is most likely what you will see implemented into fixtures as a replacement of the DMX standard.
