Hi,
So I have a 1201 Hazer made by Stage Ape lighting hazer machine. The controller in-put is 5 pin (probably DMX but not sure) and I want to be able to control it from a farther distance (controller cord is 15 feet). The controller has a smaller end then regular XLR and is just a simple "on/off" switch with NO volume/ quantity controls on it. What I want to do is convert the controller to 3 pin XLR, run that to a snake, then at the end of the snake convert it back into 5 pin to put into fog machine. Would this be possible to convert in this way? Would it lose too much voltage by the time it gets to the machine?
